CME hunt groups
Jul 10th, 2009
I need to create a setup using CME 4.x (UC520) to service 30 DDIs such that each DDI is only available via extension mobility. I've set this up fine.
I want each DDI to represent a different business and when the business is not logged in, or if they are busy I want the DDI to fallback to a central user who will pick up the number in their absense.
The customer has specced ARCExpress to do this job but I suspect it's not the right product has it can only service 4 queues, not the 30 I need.
So, can I simply use call coverage to achieve the desired results and if so, which of the many hunt options should I be looking at? It looks like call hunt, overlaid dn or hunt groups all offer something for this but I suspect the 30 DDIs may be a factor in pointing me to the correct feature.
I will ultimately want to direct the call to voice mail as a final number for the call coverage, or queue prior to the voicemail if possible.
Thanks for any pointers,
Jed
paolo bevilacqua Fri, 07/10/2009 - 03:47
  • Hall of Fame,
    Founding Member
Hi, all really depends how these business wants to answer calls and if there is a real need for queues or not. Most options should be available to you anyway.
