Phone dont stop ringing when goes off hook
Jul 10th, 2009
We have a problem in a branch office. Sometimes when a phone is ringing an the employee get the phonecall and goes off hook the phone dont stop ringing and the call isn`t connected. Or in the other way the employee would like to place a phonecall and goes off hook he dont get any dialtone.
Any idea about this issue ?
Best Regards,
chrisluven Fri, 07/10/2009 - 02:26
Sounds like a problem with the physical hook of the phone.
Try to tap on the hook-button of the phone a little bit harder when this happens again.
I know this with some older 7940 and 7960.
When they are out of warranty, open thm and clean the mechanical part of the hook, before reassebling use a LITTLE amount of grease to put it on any moving part of the hookswitch.
I hope this helps
