Dial-peer destination-pattern priority
Jul 10th, 2009
Dear all,
There are two dial-peer with 69[0-9] and 69T. Is there any priority which dial-peer will be selected first ? The following dial-peer is in Shengzhen voice router.
When user dial 691, what dial-peer will be selected ?
dial-peer voice 102 voip
description To Hong Kong Local Extension
destination-pattern 69[0-9]
session target ipv4:10.1.1.2
dial-peer voice 3 pots
trunkgroup PABX
description To Shangzhen Outgoing Call
destination-pattern 69T
forward-digits all
Man Leung
paolo bevilacqua Fri, 07/10/2009 - 04:44
  • Hall of Fame,
    Founding Member
Use preference to decide which one has to be used first.
Nicholas Matthews Mon, 07/13/2009 - 10:38
  • Red, 2250 points or more
Hi Man,
When you receive a call in-bloc, you will do a longest-prefix match. If you are matching them digit-by-digit on an FXO port you'll match the dial-peer 3 because of the T.
-nick
