Host Files?
Jul 10th, 2009
Hi All,
I'm confused. I have a simple demo network in which I plug into my 3560 which in turn is connected to various other remote devices (all configured and working okay). The IP address of MGMT interface on a particular device is - I can telnet to this device which has a hostname test. I want to be able to telnet to "test" but I have no DNS or host file configured. Any help to get me started with config of a host file on the router "test".
Thanks All.
davy.timmermans Fri, 07/10/2009 - 03:03
2 options:
ip host something
something can be everything, does not has to be necessary test
1)connect to name is only possible on the device you configured the ip host command
second possibility
edit hosts file with a text editor test
Danilo Dy Fri, 07/10/2009 - 03:03
From the device you want to use as base to connect to other devices using their hostnames, try this command.
ip host TEST
To test;
ping TEST
telnet TEST
