AIP-SSM 20 questions
Jul 10th, 2009
we have this module on an ASA 5540, while the inspection load is reaching a max of 35% , the cpu is reaching 100% sometimes.
1- how do i check the current bandwidth in Mbs being inspected ?
2- how do i check if there is drops when cpu is reaching 100%
3-if cpu hangs at 100% will fail-open work or will the module start dropping legitimate packets
4- should i upgrade my card to AIP-SSM 40 allthough inspection load is still 35% ?
Thank you
josephium Mon, 07/20/2009 - 05:08
thank you but its not , can anyone answer these questions plz.
rhermes Mon, 07/20/2009 - 07:23
To check if your sensor is dropping packets, get on the CLI and run
show interface - This will show you an averaged packet loss across all interfaces since last reset and on a per-interface basis.
show event stat past 01:00 inc missed - This will show you any peaks in your missed pckets over the last hour.
