Dead RIP route stuck in routing table!
Jul 10th, 2009
please see below output, default route stuck in VPN routing table for 15:46:40 although the ' Hold down timer expires in 0 secs' and flushed time is 240 secs. has anyone expirienced this problem? is this normal practice on Cisco router? thanks
r0#sh ip ro vrf 504-ten 0.0.0.0
Routing entry for 0.0.0.0/0, supernet
Known via "rip", distance 120, metric 4294967295 (inaccessible), candidate default path
Redistributing via rip, bgp 65500
Advertised by rip (self originated)
bgp 65500 route-map weight-0-local-pref-800
Last update from 10.250.41.86 on Serial1/0.1/1/6/3:0, 15:46:40 ago
r0#sh ip pro vrf 504-ten
Routing Protocol is "rip"
Outgoing update filter list for all interfaces is 59
Incoming update filter list for all interfaces is not set
Sending updates every 30 seconds, next due in 20 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Redistributing: static, rip, bgp 65500
Giuseppe Larosa Fri, 07/10/2009 - 03:18
  • Hall of Fame,
    Founding Member
Hello Kevin,
this is not normal
note also that
the metric is expressed as a 32 bit integer when infinity in RIP should be 16!
Verify that there is no routing loop caused by multiple mutual redistribution betweeen RIP and BGP address-family ipv4 vrf 504-ten.
But you may be hitting a bug.
What platform is this and what IOS image is running on it
Hope to help
Giuseppe
kevin.shi Fri, 07/10/2009 - 03:33
Thanks for you reply, Giuseppe.
That is 7206VXR, please see below info:
r0#sh ver
Cisco IOS Software, 7200 Software (C7200-P-M), Version 12.4(19b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 13-Jun-08 14:32 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(5a), RELEASE SOFTWARE (fc1)
r0 uptime is 1 year, 2 weeks, 1 day, 10 hours, 17 minutes
System returned to ROM by reload at 02:00:09 BST Wed Jun 25 2008
System restarted at 02:02:38 BST Wed Jun 25 2008
System image file is "disk2:c7200-p-mz.124-19b.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory.
Processor board ID 20404511
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.0
The serial interface has been down for over 15 hours. so I can fonfirm at least within these 15 hours there was no route loop. After I redeployed RIP config, routing became normal
Seems really a bug!
