Media Master Control Bar
Jul 10th, 2009
I have the problem to install the Media Master Control Bar with IE7. It's shows me following error:
"Windows has blocked this software because it can't verify the publisher" Name: MediaMasENU.cab Publisher: Unknown Publisher
Has anyone experience about this error ?
thx a lot
Patricio
Tray Stoutmeyer Fri, 07/10/2009 - 06:10
  • Cisco Employee,
Depending on the version of Unity, you may be hitting a bug
CSCsv18289 Unity mediamas.cab does not download due to improperly signed certificate
Workaround:
From the internet options in IE. Change the option in Local Intranet from
Disable "download unsigned activex" to prompt/enable "download unsigned
activex". This will allow IE to install the mediamas.cab the next time the page
is loaded.
See if that helps.
Tray
