mode cli MCU 3515
Jul 10th, 2009
I have an mcu 3515. I would like configure the EMP port setting. What is the command to do this ? Is there many commande to troubleshoot in cli mode ?
ecarabias Sun, 07/12/2009 - 22:50
Hi!
In the VxWorks type the command "modifyTargetDevice". After that you will see the menu configuration.
Regards!
jch00 Tue, 07/14/2009 - 07:03
hi,
Thanks for your answer. Is there another command in this mode to configure or troubleshooting the mcu ?
ricardorojas123 Wed, 07/15/2009 - 07:30
You can restart o rest the EMP module, and enter into the configuration menu ... press any key to star the configuration ...
