guillermohurtado Fri, 07/10/2009 - 06:02
Is there a command to kill/end a specific call on a Cisco GW AS5300/AS54000 ??
Regards.
Nicholas Matthews Mon, 07/13/2009 - 09:32
  • Red, 2250 points or more
If you use 'show call active voice brief' you can get the 4 digit HEX ID for a call based on calling/called number and remote IP address and channel.
Then you can use the command:
clear call voice causecode id , you can also try using the called/calling options instead of ID.
hth,
nick
guillermohurtado Tue, 07/14/2009 - 06:27
I can't run that command. I just have:
GW#clear call ?
fallback VoIP Fallback
threshold Clear stats about resource measurement
treatment Clear commands for call admission
Is there another way to perform this?
Best regards.
Nicholas Matthews Tue, 07/14/2009 - 11:19
It sounds like you need to upgrade IOS to use this command.
There isn't another way, unless you shut down voiceports/controllers.
-nick
guillermohurtado Tue, 07/14/2009 - 11:39
I'm running Version 12.3(26) over a AS5300, isn't it the latest?
Regards.
