Failover setup for two different ISP
sivaprakasam81
Hi All,
We are going to host VOIP. We will be getting T1 and cable connection. May I know, which Cisco router will support for Failover setup to perform between these cable and T1 connection. How can I perform the same?
Thank you
Giuseppe Larosa
Hello Sivaprakasam,
your question is not clear try to describe your requirements in more detail.
However, you can have both links in use and you can achieve fault tolerance as well.
Every Cisco router that can host a T1 link and a lan interface to cable modem can do the job.
But this is just generally speaking.
Hope to help
Giuseppe
