CUE 7.0.1 Issue
Jul 10th, 2009
I have CUE 7.0.1 (NME-CUE) in a 2821. I configured the following
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.32.128.23 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.32.128.11
no keepalive
ip route 10.32.128.23 255.255.255.255 Integrated-Service-Engine1/0
The problem I'm having is that I can't access the service-module IP, not even from the router... what did I miss?
Overall Rating: 4 (3 ratings)
wrickk_2 Fri, 07/10/2009 - 08:01
no error, can't even ping 10.32.128.23 at this point.
Kenneth Mohammed Fri, 07/10/2009 - 08:19
  • Silver, 250 points or more
what do you get when you issue
service-module service-engine 1/0 status?
does the interface show up/up?
wrickk_2 Fri, 07/10/2009 - 08:46
Service Module is Cisco Integrated-Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 7.0.1
CUE Running on NME
Kenneth Mohammed Fri, 07/10/2009 - 09:21
Does the please wait ever go away? Also Im assuming you did a shut/no shut on the interface already. You may want to try reseating the NME-CUE.
wrickk_2 Fri, 07/10/2009 - 11:25
"please wait" never changes. I tried shut/no shut several times. I re-seated the card and still nothing. I may just open a TAC case, thanks for your help.
branfarm1 Mon, 08/24/2009 - 04:56
  • Bronze, 100 points or more
Were you ever able to get this working? I'm running into the exact same situation.
--Brandon
marevaloc Mon, 02/22/2010 - 11:06
I have the same problem.
How do you resolv this issue?
tks
Paolo Bevilacqua Mon, 02/22/2010 - 12:20
  • Hall of Fame,
    Founding Member
Wrong config.
Send it.
marevaloc Mon, 02/22/2010 - 14:32
This is my config,
I can't ping 10.247.93.153
help me please!!!
tks
  interface GigabitEthernet0/0
  description Lan
  ip address 10.247.93.150 255.255.254.0
  ip helper-address 10.247.98.219
  ip helper-address 10.247.100.1
  duplex auto
  speed auto
  media-type rj45
  h323-gateway voip interface
  h323-gateway voip bind srcaddr 10.247.93.150
interface Integrated-Service-Engine2/0
  service-module ip address 10.247.93.153 255.255.254.0
  service-module ip default-gateway 10.247.93.150
  no keepalive
Paolo Bevilacqua Mon, 02/22/2010 - 14:49
  • Hall of Fame,
    Founding Member
You do not have the host route for the module.
Vaijanath Sonvane Tue, 02/23/2010 - 02:42
Hi Guys..
You need to add the static route for the Service Engine module. For example Service Engine Module IP address is 10.68.90.4 you need to add below static IP address.
Router(config)#  ip route 10.68.90.4 255.255.255.255 Integrated-Service-Engine1/0
Note:Please see the mask in the route..
Vaijanath
marevaloc Thu, 02/25/2010 - 07:02
Tks all.
I add the static route, and ping succesfull.
But the browser with ip address of "CUE" don't response.
Any idea?
