Voice hunt groups in CME
I am running cme version 7.0.1, cue version 3.0, the ios is 12.4.22yb. I have configured a voice hunt group as shown below.. ALl other phones work fine it is only this hunt group, it appears as it doesnt see the final which is the pilot of cue. I get a fast busy after 30 seconds. The phones are sccp, there is a gdm mailbox for the pilot, All the config looks correct according to the guides.. Anyone seen this
I am suspecting bug..
voice hunt-group 2 parallel
final 399
list 250,229,246,249,247,248
timeout 30
pilot 223
Overall Rating: 5 (1 ratings)
douhanm Sat, 07/18/2009 - 10:20
sounds like a codec issue, your incoming call is probably using another codec than G711 ulaw that your CUE is using, you must make sure that calls to ext 399 come in as G711 ulaw directly then you the forward will work just fine.
