Convert switchport to a L3 port similar to a router
Giuseppe Larosa Fri, 07/10/2009 - 09:13
  • Hall of Fame,
    Founding Member
Hello Nicholas,
if you had an enterprise image EMI the answer would be yes 100%.
More modern switches with base image can support intervlan routing but miss support of advanced routing protocols.
SMI in 3550 should be able to be a multilayer switch.
try the following:
int f0/x
no switchport
ip address x.x.x.x y.y.y.y
no shut
if it accepts this and you can reach a device on the other end of the port you are fine
Hope to help
Giuseppe
Leo Laohoo Fri, 07/10/2009 - 17:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It's been a loooooooooooooong night but you may need the "ip routing enable" first.
