Forced Auth Codes
Jul 10th, 2009
I am using Call Manager 6.0. i have created some auth codes. but these auth codes are users based is there any way to restrict autcodes with extension. Just like my extension is 2001 and my auth code is 12345. so if somebody wants to use my auth from diff extension it should not be work. it should be working for 2001 only. is it possible. please let me know if anyone have idea about that. Thanks, Mitesh
Jonathan Schulenberg Fri, 07/10/2009 - 10:52
  • Cisco Designated VIP,
    2017 IP Telephony
No. Use extension mobility instead to get this specific with dialing privileges.
mitesh.mishra Fri, 07/10/2009 - 11:05
Actually i have more than 700 ip Phones which have fixed lines. if i use extension mobility it will be a terrible mess for me.
Jonathan Schulenberg Fri, 07/10/2009 - 12:58
    2017 IP Telephony
FACs work on an code-assigned authorization level. All you can do is assign a privilege level to an individual FAC and specify an minimum level on the route pattern. They were not designed to provide authorization on an originating-device basis.
If you need to constrain the ability to dial a pattern to a user (authentication) and have per-user authorization, you can do this by using EM to get a per-user/device authentication to occur and then assigning a line CSS with that user's unique privileges.
