asa5505v8 tcp syn denied on inside
Jul 10th, 2009
"Inbound TCP connection denied from 1.4.19.244/1635 to 1.4.20.212/4001 flags SYN on interface inside"
The vlan on the inside interface (vlan19) also needs access to systems on vlan20 so we have a static route on the asa that points to a router that also sits on vlan19. I can ping the two vlans from the asa's inside interface but I'm not sure why the above error occurs or how to stop it.
Jon Marshall Thu, 07/16/2009 - 10:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Keith
So is the default-gateway for clients on vlan 19 the ASA inside interface ?.
If so have you added this to your config -
asa(config)# same-security-traffic permit intra-interface
if you don't have that in your config traffic will not be allowed back out the same interface it arrived on to get to it's destination.
Jon
