service finger vs. ip finger
Jul 10th, 2009
The command lookup tool verbage for default behavior on these commands is very elusive/confusing.
This is the way I understand it:
12.0 - 12.1(5)
service finger
default = ENABLED
ip finger
12.2 - onward
integrated-introduced in 12.2
default behavior is DISABLED.
If you could point me in to the
factual clear cut information from
Cisco that would be awesome.
I am not 100% sure but I honestly
think there could be a disparity between
whats in the Mstr. Cmd. Refs.
vs. Command Lookup Tool
Could be wrong though.
Respectfully submitted.
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 07/10/2009 - 11:36
Per the documentation:
service finger
The service finger command has been replaced by the ip finger command. However, the service finger and no service finger commands continue to function to maintain backward compatibility with older versions of Cisco IOS software. Support for this command may be removed in a future release. See the description of the ip finger command for more information.
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_r1.html#wp1014016
And the 'IP Finger' documentation indicates the following:
11.3 --- This command was introduced.
12.1(5), 12.1(5)T --- This command was changed from being enabled by default to being disabled by default.
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_f1.html#wp1023392
HTH,
__
Edison.
