CME7.1 + CUE7.0: Transfer to Voice Mail
Jul 10th, 2009
the softkey TrnsfVM on IP Phone works if followed by inputting an extension, but if I push the speed dial button instead, I hear error message" there's no mailbox associated with the extension", then the call is transferred back by CUE.
is this normal behavior?
pradeepde Thu, 07/16/2009 - 15:06
If the call does go to voicemail but the wrong greeting is played--or even one that states that there is no mailbox associated with this number--then the problem is likely that the E.164 number is not assigned to the subscriber.
xiaoliangyue Tue, 07/21/2009 - 14:41
if you input the extension mannually, the call goes thru. Cisco TAC determines this is caused by a bug, will be resolved on 12.4.24T2
