VG 224
Jul 10th, 2009
I have 2 VG224 gateways in my network. The first one is working fine, i'm having issues with the second one.
After troubleshooting the unit i found out the the voltage i'm getting for voice ports is very low. It's aroung 10V per port.
I remember i had similar issue long time ago but i don't really remember what the command i used to bring the port voltage up. Any help?
jbayuka Thu, 07/16/2009 - 05:55
  • Bronze, 100 points or more
Use the command “alt-battery-feed feed2” to bring the port voltage up.
JimPatch01 Tue, 07/21/2009 - 07:47
Is this a voice-port command? I don't see it as an option under commands.
thanks
Nicholas Matthews Tue, 07/21/2009 - 09:21
  • Red, 2250 points or more
it's a hidden command. try putting it in, and the router should take it.
-nick
sohaildxbfze Sun, 10/18/2009 - 23:45
this hidden cisco command doesnt work under my vg224 fxs port
vg ios : vg224-i6s-mz.124-5b.bin
Hythim Ali El Hadad Mon, 10/19/2009 - 01:40
  • Silver, 250 points or more
It'll be accepted after upgrading your ios
But this command won't raise your output volt to -48 v, only it'll be about 38 or 39, so you may need an extra transformer on the needed line to have more voltage
thanks
