local and ldap server groups
Jul 10th, 2009
I currently have a number of local users on my ASA and I'm working to migrate them to ldap. I want to setup ldap so I can test it but don't want to affect the local users. What is the best approach for this?
pompeychimes Fri, 07/10/2009 - 19:05
  • Bronze, 100 points or more
How about creating another context. That's if your model/code supports it.
Or do you have another ASA that you can use for testing.
One other way to test is to use Pemu.
srue Sun, 07/12/2009 - 18:39
  • Blue, 1500 points or more
running in multiple context mode, the asa doesn't support any VPN's.
create another tunnel-group that uses the LDAP server for authentication.
I'm attaching a document I created a while back to help with LDAP/remote vpn's on the asa.
esossamon Mon, 07/13/2009 - 13:08
Thank Steven,
Yes creating the new tunnel group is that what I needed to do. Thanks!
