BGP Question
Answered Question
Jul 10th, 2009
  • Blue, 1500 points or more
router BGP 65000
network 1.1.1.0 mask 255.255.255.0
ip route 1.1.1.0 255.255.255.0 null0 254
I need the static route and it has to be an exact match because the network command is utilizing the 'mask' keyword. Thats not my question.
What if I wanted to advertise an aggregate address, do I still need the static route?
router BGP 65000
aggregate-address 1.1.1.0 255.255.255.0 as-set summary-only
Correct Answer by Edison Ortiz about 7 years 9 months ago
Yes, you still need the static route because the route needs to be brought into BGP so it can be aggregated and in order to bring the route into BGP, it must exist in the RIB.
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Fri, 07/10/2009 - 18:07
  • Hall of Fame,
    Founding Member
__
Edison.
lamav Fri, 07/10/2009 - 19:05
Thanks, Edison...Thats what I figured, just wanted to make sure.
Hope all is well with you...
Victor
Edison Ortiz Fri, 07/10/2009 - 19:15
  • Hall of Fame,
    Founding Member
Hope all is well with you and thanks for the rating.
