PIX 515 stucks and sometimes doesnt stuck!
Jul 10th, 2009
here is the boot session.
Cisco Secure PIX Firewall BIOS (4.2) #0: Mon Dec 31 08:34:35 PST 2001
Platform PIX-515E
System Flash=E28F128J3 @ 0xfff00000
Use BREAK or ESC to interrupt flash boot.
Use SPACE to begin flash boot immediately.
Reading 102912 bytes of image from flash.
PIX Flash Load Helper
Initializing flashfs...
flashfs[0]: 7 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 16128000
flashfs[0]: Bytes used: 14089216
flashfs[0]: Bytes available: 2038784
flashfs[0]: Initialization complete.
Booting first image in flash
Launching image flash:/pix802.bin
128MB RAM
Total NICs found: 2
mcwa i82559 Ethernet at irq 10 MAC: 001e.1347.f261
BIOS Flash=am29f400b @ 0xd8000 MAC: 001e.1347.f262
flashfs[7]: 7 files, 3 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 16128000
flashfs[7]: Bytes used: 14089216
flashfs[7]: Bytes available: 2038784
flashfs[7]: flashfs fsck took 15 seconds.
flashfs[7]: Initialization complete.
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
please help, I will be appreciated for any help.
Det
guibarati Tue, 07/14/2009 - 05:19
  • Bronze, 100 points or more
If I understand, sometimes the PIX but up sometimes no.
I've solved a problem like this once by exchanging the internal battery.
rate if it help you.
