Cisco Wireless Lan Manager
I'm fairly new with getting cisco AP and 4400 working together.
I inherit a network of 100 cisco access points and a wireless lan manager. The network needs to be updated with a new subnet. However, each AP has a static ip address.
Can you provide any suggestions as far:
1) how to change all the APs to new subnet address
2) how to configure the wireless lan manager to work with the APs?
Lucien Avramov Sat, 07/11/2009 - 18:39
  • Red, 2250 points or more
What do you mean by Cisco Wireless Lan Manager? Wireless Control System (WCS) ? Wireless Lan Control System (WLSE)? the 4400 Wireless Lan Controller UI?
In any case, you can change individually the ip addresses of the access points from the WLC GUI, the WCS but there is no easy way to change it as a bundle.
In WLC UI: go to Wireless -> Access Points -> All APs. Click on the AP in question and in IP Config, uncheck static IP.
WCS : Configure -> Access Point. Click on the AP and change the IP.
I dont see a way to change this in a template for all the APs simultaneously on the software.
I suggest is to use the CLI on the WLC with the command :
(Cisco Controller) >config ap static-IP disable .
You can list all your aps in a file and then paste the output on the CLI of the WLC :
config ap static-IP disable AP1
yes
config ap static-IP disable AP2
yes
Be aware that your APs will reboot after entering this command.
Leo Laohoo Sun, 07/12/2009 - 15:35
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If it is the WLC, what firmware are you running? 5.2.157.0 firmware does NOT like static AP IP Address. You can put the static IP Address in BUT the AP's will have a different IP Address.
Cisco 440X Series Wireless LAN Controllers Deployment Guide
http://www.cisco.com/en/US/docs/wireless/technology/controller/deployment/guide/dep.html
Hope this helps.
Lucien Avramov Sun, 07/12/2009 - 17:23
If you want to keep static-IP and move it, you can have the following command line script to paste in your WLC :
config ap static-IP enable ' '
yes
This will also reboot the AP as there is an IP address change.
Regardless of the code of WLC, check the release notes for open defects :
4400 WLC :
http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html
2100 WLC :
http://www.cisco.com/en/US/products/ps7206/prod_release_notes_list.html
I'm running version 3.2.150.10 on my Wireles Lan Controller.
Two questions...
1) Do I need both a wireless lan manager and the wireless controller?
2) When I reset the APs, they do not connect to my Wireless Lan Controller. What kind of configuration needs to go into Wireless Lan Controller and if there is something wrong?
thanks
Leo Laohoo Wed, 07/22/2009 - 14:57
  • Hall of Fame,
    2017 LAN, Wireless
Hi Pedro,
The "lwapp" enable command is disabled if the AP is running on the LWAP image. In enable mode, check if you have two IOS in the AP: one for LWAP and the rcovery image ("RCV" in the filename). If there is, you can delete the LWAP image (delete /f /r flash:) and allow the AP to boot into the RCV image before trying the "lwapp" enable command.
What are your AP's models? Firmware 3.X will NOT support 1140 & 1250 APs.
Hope this helps.
NOTE: Not being picky, but do you have an idea why are you still using the 3.X firmware?
Leo Laohoo Wed, 07/22/2009 - 17:56
  • Hall of Fame,
    2017 LAN, Wireless
Hi Pedro,
Managing Controller Software and Configurations
http://www.cisco.com/en/US/docs/wireless/controller/5.1/configuration/guide/c51mfw.html
Have a read of the link above. Take special attention to Table 8-1 Upgrade Path. Before you do any upgrade, I recommend the following:
1. I will not recommend any version for you to upgrade to. This is your choice.
2. When choosing the version of your choice, read the Release Notes.
3. I recommend that you upgrade the Bootstrap FIRST. Bootstrap has the suffix -ER in the filename and contains patches and fixes not associated to the firmware.
Hope this helps.
