create static route on 4506E to 7200 router
Answered Question
Jul 11th, 2009
I'm having an issue where I can't create an ip address on a switch port for a firewall. I've done it before on a non-HA setup where the connection was made on the core switch directly connected to the router. This time the connection will be on a distribution-layer vtp client switch. There is a staticly-mapped subnet on the router to a virtual address. Every time I want to just create a port with IP Address, it fails why?
Correct Answer by Reza Sharifi about 7 years 6 months ago
Earl,
Did you remeber to do a no switch port on that port to make a routed port?
Reza
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Sat, 07/11/2009 - 17:40
Earl,
Reza
