caller ID
hani-molani
Dear all
I want to block caller ID on specific IP PHONE.
please guide me
Jaime Valencia
ALWAYS mention what you use
I'm just going to go ahead and think this is for CCM/CUCM
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fshosp.html
PLEASE search NetPro, this has been asked plenty of times before
java
if this helps, please rate
java
Hi Java
Hope you are OK.
I would like to know how can block a caller to an internal extension. Its mean that an extension is receiving a maliciousos call from a PSTN phone, I want to reject to the PSTN phone that he cant reach this extension or all, I am using mgcp gateway CUCM 4.2
best regards
Andres
PLEASE SEARCH NetPro for answers.
This is just one of the HUNDREDS of posts for this same question that you can find if you search NetPro:
IP Telephony: Blocking incoming numbers on voice gateway CUCM 5
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd4043c
Simple answer is: NO way with MGCP, you need H323.
java
java
