Help with improving this Router Config
Jul 12th, 2009
I am building a small network for a 70-user business in town. They have two Cisco switches connecting to a Cisco 3800 series router with Advanced IP services IOS. The intention being to use the built-in IPS feature.
Essentially here is the way its going to be wired.
Switch 1 >> Trunk >> Switch 2 >> Router >> WAN
I have SDM installed on one of the PCs connected to one of the two switches.
The Router has Dynamic NAT, Firewall and IPS enabled. The customer is very particular about this network being good at intrusion prevention.
Below is my Config (fake IPs etc.). What else can I do to improve this configuration ?
!version 12.4
hostname MyRouter
!DR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 !@#%@$#%@#$!@!@#!$!@#
no aaa new-model
ip cef
ip domain name yourdomain.com
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip ips sdf location flash://256MB.sdf autosave
ip ips notify SDEE
ip ips name sdm_ips_rule
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-1408452671
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1408452671
revocation-check none
rsakeypair TP-self-signed-1408452671
crypto pki certificate chain TP-self-signed-1408452671
certificate self-signed 01
<clipped>
quit
username <myuser> privilege 15 secret 5 <mypassword>
interface GigabitEthernet0/0
description WAN_OUTSIDE
ip address 222.22.121.34 255.255.255.0
ip access-group 101 in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_LOW out
ip ips sdm_ips_rule in
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
description LAN_INSIDE
ip address 192.168.10.1 255.255.255.0
ip access-group 100 in
ip nat inside
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 7 interface GigabitEthernet0/0 overload
access-list 7 permit 192.168.10.0 0.0.0.255
access-list 23 permit 192.168.10.203
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 222.22.121.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.10.0 0.0.0.255 any
access-list 101 permit icmp any host 222.22.121.34 echo-reply
access-list 101 permit icmp any host 222.22.121.34 time-exceeded
access-list 101 permit icmp any host 222.22.121.34 unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
! <vty stuff clipped>
end
Full config attached.
Rick Morris Sun, 07/12/2009 - 15:05
  • Silver, 250 points or more
looks pretty good.
What routing protocol are you using? I did not see any routes so I do not know if there are any suggestions there, for instance if you are running bgp you could use a password in the bgp config with the peer. Other than that you look like you have a pretty good config there for what you need.
slingblade Sun, 07/12/2009 - 15:41
engagerocks, you are correct on the lack of routing protocol.
This router will be connected via GE0/0 to a service provider's router. Is there a need for anything more than a static route ?
