2620XM getting System received a Software forced crash
Jul 12th, 2009
  • Blue, 1500 points or more
Someone was trying to update the IOS and afterwards we are getting this during reboot.
System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xd06b6c
Error : memory requirements exceed available memory
Memory required : 0x0219D508
*** System received a Software forced crash ***
signal= 0x17, code= 0x4, context= 0x800805d0
PC = 0x0, Vector = 0x0, SP = 0x0
rommon 1 >
What can I do to resolve this. I can't seem to erase or format anything to start over.
Mike
Overall Rating: 4 (1 ratings)
Giuseppe Larosa Sun, 07/12/2009 - 11:00
  • Hall of Fame,
    Founding Member
Hello Mike,
you should load the old image
check if the rommon supports tfpdwnld you may need to set some parameters like ethernet ip address but you should be able to have it load an image from a tftp server directly connected to the ethernet.
Then later you can write the right image on the flash.
I remember we did for a C1721 with the same problem in this way.
Edit:
my memory failed it looks like you can only use xmodem to load a new image from 2600 rommon:
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_tech_note09186a008009433b.shtml#image
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008009433b.shtml#image
the idea is still the same
Hope to help
Giuseppe
burleyman Mon, 07/13/2009 - 03:56
I will give it a shot.
Mike
