FWSM & Software cryptographic mode by IOS
Jul 12th, 2009
I have the following scenario: FWSM is configured and since it doesn't support VPN. Software cryptographic mode will be used. Thus, confiugration will be done on the IOS router itself. The setup is not working unless we change the configuration port and remove the Vlan FWSM configuration from the port.
Below is the configuration when port is assigned to the fwsm vlan:
interface GigabitEthernet2/3
description Connection to Internet
switchport access vlan 601
switchport mode access
no ip address
crypto map mparking-map
is there a way to fix the above issue and use FWSM and do VPN encryption on the router??
Any help is really appreciated.
