Rob Huffman Sun, 07/12/2009 - 12:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nasry,
Servers within a Cluster do not need to match. So you can use a mix of 7825,7835,7845 models within the Cluster.
General Clustering Guidelines
The following guidelines apply to all Unified CM clusters:
Note A cluster may contain a mix of server platforms, but all servers in the cluster must run the same Unified CM software release.
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/callpros.html#wp1043559
Hope this helps!
Rob
