multiple SVI's on 2940
I didnt have any luck with searching, but when i try to configure 2 SVI's (interface vlan 1, interface vlan 2) on my 2940 the previously up and up interface goes down when i do a 'no shut' on the new one.... here's the output and config...
interface Vlan1
ip address 192.168.0.101 255.255.255.0
no ip route-cache
interface Vlan999
ip address 10.1.1.1 255.255.255.0
no ip route-cache
shutdown
Switch(config-if)#do show ip int bri
Vlan1 192.168.0.101 YES manual up up
Vlan999 10.1.1.1 YES manual administratively down down
Switch(config-if)#int vlan 999
Switch(config-if)#no shut
Switch(config-if)#
17:39:10: %LINK-3-UPDOWN: Interface Vlan999, changed state to up
17:39:10: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
17:39:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan999, changed state to up
17:39:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Edison Ortiz Sun, 07/12/2009 - 13:03
  • Hall of Fame,
    Founding Member
2940 is a layer2 switch and routing isn't allowed. The SVI in a 29xx is purely for management purposes so you only need one.
HTH,
__
Edison.
