Study materials for data center design specialist?
Jul 12th, 2009
I plan to take 642-971 DCNID (Designing Cisco Data Center Network Infrastructure). Can anyone recommend study materials? I was not able to find any.
Thanks a lot
mherald Mon, 07/13/2009 - 11:43
I was looking for this as well. I couldn't really find any. There were 2 courses on the PEC if you have access. The courses were fairly good, but really short (and incorrect) with some of the really advanced services.
I know this is tough, but I have found if you have an ACE, see if you can sneak in a test lab context. That is what I did.
gwhuang5398 Thu, 07/16/2009 - 19:00
Thanks for the info. I have access to PEC, but have not used it much.
Did you used ACE to practice for the exam? To be honest, I've never used ACE or Nexus products.
mherald Fri, 07/31/2009 - 10:48
I have not taken the exam nor have I really planned on it. I have acess to 4 physical boxes which really helped and I ahve worked on CSSes for quite some time. I am migrating applications from the CSS to the ACE, but I hadn't worked on the ACEs before.
Now that I have done a few migrations and added features such as compression, Flash Forwarding and delta (I still haven't gotten to the more advanced features), I feel very comfortable. Maybe I will take a look at the exams.
