Phone proxy cert question
Jul 12th, 2009
Where do I find the Cisco_Manufacturing_CA for a CME and ASA phone proxy install?
m-ketchum Mon, 07/13/2009 - 07:28
Thanks. I finally did find this in my seraching and copy the certs from this page.
I've gone through the config a few times and can't get this proxy feature to work. I'm sure I'm missing something. The phone doesn't even appear to be trying to connect, or at least I don't see any activity at the proxy when trying to connect.
m-ketchum Mon, 07/13/2009 - 07:25
Thanks, but I can't really do that if I'm using call manager express.
natedog Fri, 07/17/2009 - 07:11
Were you able to make any progress on this? I am looking to roll out the same solution and I haven't found any solid guides on deploying this with CME.
