SPA scale options on SIP-400
Jul 12th, 2009
  • Bronze, 100 points or more
Hi All,
Are there any scalability limitations on 7600 with a SIP-400 module?
Specifically looking for pointers in identifying the maximum number of 1xGig ports supported per SIP-400 on a 7600 router.
~sultan
Overall Rating: 2 (1 ratings)
sultan-shaikh Mon, 07/13/2009 - 22:26
Hi Jerry,
Thanks for your response.
I am looking for a 'matrix' that gives me various combinations I can stick in, though you mention that each bay can support upto 2x1G or 5x1G, that is not the case.
When I try to stick in 3 nos. of 2x1G V2 SPA I get a message something like capacity exhausted/expended etc... and the SPA goes 'down'. In addition there are loads of other SIP/SPA incompatibilities... I wonder how difficult it would have been to make a single SIP capable of having ALL the available SPAs in any combination... but then this is Cisco :-)
I have also spoken to TAC, but the response was limited to 'Please check the product specifications'.
~sultan
Jerry Ye Tue, 07/14/2009 - 06:36
  • Cisco Employee,
Hi Sultan,
Here is what I found from the product specification from the link I gave you before:
Table 1. Features and Benefits of Cisco 7600 SIP-400
CPU
Ability to run 4 GE line rate for 64-byte packets, and OC-48 line rate for 48-byte packets for POS, HDLC, etc. with select services
HTH,
jerry
sultan-shaikh Wed, 07/15/2009 - 18:30
Hi Jerry,
Really appreciate your response.
So this essentially means that I can have two 2GE SPA per SIP-400 module, that is the maximum I can scale!!
I will be left with two unused bays...
~sultan
Jerry Ye Thu, 07/16/2009 - 06:04
  • Cisco Employee,
Hi Sultan,
I think that is the case. Please keep in mind that the SIP-400 is not designed for the 2GE SPA only, other SPA, such the 4xDS3, etc. For the 4xDS3, I have seen customer put 4 SPA into a SIP-400 and no complain from the IOS.
HTH,
jerry
sultan-shaikh Mon, 07/20/2009 - 05:27
Hi Jerry,
You inputs have been helpful, thanks for your replies..
Cheers
~sultan
