How to Give a name / label to FXO ports ?
Jul 12th, 2009
FXO port 0/0/0, label as “A1”
FXO port 0/0/1, label as “A2”
FXO port 0/0/2, label as “A3”
So when incoming call from FXO port 0/0/0 ringing in IP Phone, in IP Phone displayed “A1”
When incoming call from FXO port 0/0/1 ringing in IP Phone, in IP Phone displayed “A2”
Using Call Manager v.7.0
How to configure this ? (MGCP & H.323)
Please help me.
Overall Rating: 4 (1 ratings)
paolo bevilacqua Mon, 07/13/2009 - 00:38
  • Hall of Fame,
    Founding Member
Use "station-id name".
paolo bevilacqua Mon, 07/13/2009 - 01:24
  • Hall of Fame,
    Founding Member
Works with H.323. If you're using MGCP, I have no idea if and how it can be done.
susanto.liu Mon, 07/13/2009 - 02:05
So, from You experience, from Router as VG connect to CUCM using H.323, which a station-id was configured in Router, will be shown on IP Phone display when incoming call ?
Thank's for You support.
James Hawkins Mon, 07/13/2009 - 02:19
  • Gold, 750 points or more
For MGCP just set the Display (Internal Caller ID) for the Directory Number within CallManager - just the same as any DN used by IP phones etc.
susanto.liu Mon, 07/13/2009 - 02:29
are You sure? I think, it is caller ID of Extension, for extension call to extension. Not for caller ID of FXO.
paolo bevilacqua Mon, 07/13/2009 - 04:41
  • Hall of Fame,
    Founding Member
It should, works with CME for example.
