Switch Hyper Terminal Problem
Answered Question
Jul 12th, 2009
when we want to connect switch though Hyper Terminal it showing following problem:-
% No defaulting allowed
Enter interface name used to connect to the management network from the above interface summary:
Correct Answer by Giuseppe Larosa about 7 years 8 months ago
Hello Ravi,
the switch has an empty configuration and you are during initial setup where it puts you questions like the one you have reported.
This question asks what of the interfaces with an ip address has to be used to look for a default gateway/default route
you can skip all this and you can manually configure the device or you can take advantage of initial setup to have some parameters configured like hostname, ip addresses on interfaces and where to look for a default gateway/default route
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 07/14/2009 - 06:01
  • Hall of Fame,
    Founding Member
Hello Ravi,
Hope to help
Giuseppe
