07-12-2009 11:45 PM
I'm trying to do IOS-to-IOS L2TP multilink to incease the throughput of DSL by using multiple lines. The problem I've encountered is IPCP negotiation does not successfully complete when I bond 2 (or more) virtual-PPP interfaces into a multilink interface. At the LCP layer things seem to be fine e.g. virtual-ppp interfaces get bundled togther on both sides.
The LNS keeps sending the client a CONFREQ to which it responds, but after that there is a timeout (LNS does not like what it gets back), so IPCP never completes and the virtual-access interfaces never become operational.
If I remove the multilink interface and add ip addr neg + chap to the virtual-ppp interfaces, each one comes up independantly with their own IPs. Test (summary) configs as follows;
L2TP Client Router
pseudowire-class bdsl
encapsulation l2tpv2
interface Multilink1
ip address negotiated
no cdp enable
ppp authentication chap callin
ppp chap hostname l2-user1
ppp chap password 0 l2-pass1
ppp multilink
ppp multilink group 1
interface Virtual-PPP1
no ip address
no cdp enable
ppp multilink
pseudowire 50.50.50.50 10 pw-class bdsl
interface Virtual-PPP2
no ip address
no cdp enable
ppp multilink
pseudowire 50.50.50.51 20 pw-class bdsl
interface Dialer1
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp chap hostname user1
ppp chap password 0 pass1
interface Dialer2
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
no cdp enable
ip route 50.50.50.50 255.255.255.255 Dialer1
ip route 50.50.50.51 255.255.255.255 Dialer2
LNS Router
aaa new-model
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
multilink virtual-template 1
vpdn enable
vpdn-group l2-clients
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
username l2-user1 password 0 l2-pass1
interface Loopback0
ip address 150.150.150.1 255.255.255.255
interface FastEthernet0/0
ip address 50.50.50.51 255.255.255.0 secondary
ip address 50.50.50.50 255.255.255.0
interface Virtual-Template1
ip unnumbered Loopback0
peer default ip address pool l2-pool
no keepalive
ppp multilink
ip local pool l2-pool 150.150.150.100 150.150.150.110
So my question is, does anyone know if the above config is possible? If so what paramters could be tuned to get IPCP to complete on the Multilink interface?
Lastly if anyone has an alternate method of achieving tunnel bonding over multiple dynamic IP DSL (Dialer) interfaces, I would be very interested.
PS: Testing done on IOS 12.4(15)T7 Adv IP Srv
07-17-2009 02:01 PM
If the subnet mask is not available from either the NRP configuration or the RADIUS user profile, the NRP rejects IPCP subnet mask negotiation from the CPE.
07-18-2009 09:19 AM
Tried every possible combination for setting the mask using ppp ipcp mask, however it made no difference.
I'm starting to think this is a bug/incompatibility in IOS between the Multilink & Virtual-PPP interfaces. If one looks at PPP neg debugs on either end ...
LNS Router
Jul 18 19:09:25.531: Vi4 IPCP: O CONFREQ [REQsent] id 4 len 10
Jul 18 19:09:25.531: Vi4 IPCP: Address 150.150.150.1 (0x030696969601)
Jul 18 19:09:27.543: Vi4 IPCP: Timeout: State REQsent
L2TP Client Router
Jul 18 19:09:25.510: Mu1 IPCP: I CONFREQ [ACKsent] id 4 len 10
Jul 18 19:09:25.514: Mu1 IPCP: Address 150.150.150.1 (0x030696969601)
Jul 18 19:09:25.518: Mu1 IPCP: O CONFACK [ACKsent] id 4 len 10
Jul 18 19:09:25.518: Mu1 IPCP: Address 150.150.150.1 (0x030696969601)
one can see that the LNS Router sends out a CONFREQ to which the L2TP Client seems to reply with a CONFACK, however if one traces the wire, only the original CONFREQ is seen. The response the L2TP Client Router believes it sent is never seen on the wire. This is where the bug/incompatibility lies, even when using the latest version of IOS 12.4(24)T on both ends.
Thanks for your input anyway.
