ACL to block broadcast and multicast on one switch port
Jul 12th, 2009
This is probably going to be a very easy question for most of you but it would help me quite a bit.
What I want on one of our 3560 series switches is to prevent any broadcast and multicast traffice going to a port.
The reason for this is that there is a router behind it (not ours but supplied by our telecom company) which makes a connection to another office and I want the line (as its not a very big one) to be as clean as possible.
Its probably going to be something like this but just not sure if this is correct :
access-list 10 deny 255.0.0.0 0.255.255.255
access-list 10 deny 224.0.0.0 7.255.255.255
access-list 10 permit any
Thanks!
stefanmansier Mon, 07/13/2009 - 03:25
So should I use protected ports instead ?
The article doesn't mention ACL's.
ajenks Fri, 10/21/2011 - 08:09
I am just looking at this document for a similar requirement as the original post - but isn't storm control for Ingress traffic?
ajenks Fri, 10/21/2011 - 09:12
Sure - but the original post was about not forwarding this traffic OUT through a specific port, so Egress (something I want to do) but dont think this is possible?
cadet alain Fri, 10/21/2011 - 10:32
if you do this
Switch(config-if)# storm-control multicast level 0
Then no more traffic will enter the port as soon as multicast packet enters the port   because storm-control for multicast wiil block unicast also when the threshold is hit.
Alain.
kishan1984 Tue, 07/14/2009 - 04:34
try enabling igmp snooping(default is enable) and also type one command to enable switch to itself function as a igmp querier.
