Error register QPM 4.1.1 in LMS 3.1 Portal
Answered Question
Jul 12th, 2009
When I try to register QPM 4.1.1 in our Ciscoworks LMS 3.1 portal in a multiserver trust I get this message:
Problem with File /WEB-INF/screens/cmic/Application_Registration/Imported_Application_Summary.jsp!!!Getter for property importSummary threw exception: java.util.NoSuchElementException
I'm using CiscoWorks local authentication without ACS integration. DCR replication and single sign-on works fine.
Overall Rating: 5 (1 ratings)
surearum Tue, 07/14/2009 - 04:01
Hi Tobias Kraemer,
Please send me the install & MDC logs if you have a valid license.
I guess you are having the Evaluation license for QPM, which is expired already.
Because of the license expiry only, the registration is not happening.
Suresh.A
t.kraemer Sun, 07/19/2009 - 23:53
Hi Suresh,
could you plese provide me the path and filename of the files you want? Thx
t.kraemer Thu, 07/23/2009 - 06:31
Hi Suresh,
thanks for your email. As you suggested, I copied the CSCOPx/objects/data/cmf/cmic/mst-templates/qpm.xml from the QPM server to the LMS server.
After that I was able to add QPM by "Register From Templates" instead of "Import from Other Server".
surearum Thu, 07/23/2009 - 06:41
Hi Tobias,
Its nice to hear that the problem is solved completely.
Thanks for the updates.
Suresh.A
