Brandon Buffin Mon, 07/13/2009 - 05:52
  • Purple, 4500 points or more
Yes, you can use SRST with an H.323 gateway. You would basically just need to configure phone support. See the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_wlan.html#wp1331691
This is assuming that you have proper dial peers in place. You would also need to consider how calls get routed to voicemail, AAs, etc. when SRST is active.
Hope this helps.
Brandon
