ISDN E1 - 2801 - 64 DSP - %Insufficient resources to create pri-group
Answered Question
Jul 13th, 2009
OVR-LAN-V-GW1#sho inv
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801 , VID: VN/A, SN:
NAME: "VIC 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN:
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN:
S2S-OVR-LAN-V-GW1#
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
controller E1 0/0/0
framing NO-CRC4
S2S-OVR-LAN-V-GW1(config-controller)#pri-group timeslots 1-31
% Not all config may be removed and may reappear after reactivating the logical-interface/sub-interfaces
%Insufficient resources to create pri-group - it has been removed
S2S-OVR-LAN-V-GW1#sho flash
-#- --length-- -----date/time------ path
1 27352008 Jul 10 2009 17:39:42 +01:00 c2801-spservicesk9-mz.124-25a.bin
36532224 bytes available (27353088 bytes used)
sho ver:
System image file is "flash:c2801-spservicesk9-mz.124-25a.bin"
Cisco 2801 (revision 5.0) with 352256K/40960K bytes of memory.
Processor board ID FHK084711TB
2 FastEthernet interfaces
2 Channelized E1/PRI ports
4 DSPs, 64 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62592K bytes of ATA CompactFlash
Correct Answer by pcameron about 7 years 7 months ago
The suggestion was not to move the DSP module to slot 1, it was to move the VWIC card to another slot. If you still need convincing, this URL explicitly states the limitation on slot 0 -
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/01_hw.html#wp1089015
Under Figure 7, it states the following -
Note Slot 0 does not support PRI on T1/E1 VWICs, only channel-associated signaling (CAS) digital voice.
Overall Rating: 3.7 (6 ratings)
nwkotze@hotmail.com Mon, 07/13/2009 - 10:00
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Same, do not work...
karldbrooks Mon, 07/13/2009 - 05:25
- Have you got any H/W conference or transcoding configured on the same gateway? If not try upgrading the IOS to a T train release on a ipvoice feature set.
nwkotze@hotmail.com Mon, 07/13/2009 - 05:52
S2S-OVR-LAN-V-GW1#dir
Directory of flash:/
1 -rw- 47246564 Jul 13 2009 13:54:30 +01:00 c2801-advipservicesk9-mz.124-22.T.bin
63864832 bytes total (16617472 bytes free)
S2S-OVR-LAN-V-GW1#
Still not working...
nwkotze@hotmail.com Mon, 07/13/2009 - 06:35
S2S-OVR-LAN-V-GW1(config)#card type e1 ?
<0-0> Card slot number (always 0 for 1800 series & 2801 routers)
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 1
WIC slot is empty or does not support clock participate
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 0
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 2
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 3
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 4
Slot 1 do not support Voice Cards!!!!!
nwkotze@hotmail.com Mon, 07/13/2009 - 10:07
E1 is only supported on Slot 0:
philippgrafl Mon, 07/13/2009 - 13:01
Slot 0 does not support this card, even Cisco is shipping it in this position.
Try it. Really. Power down the router, move the card from Slot 0 to Slot 1 or 2. Power up the router. In CLI you will be able to configure it with card type in position 1 or 2. As long as you have not moved the card physically tp Slot 1 or 2 it will always show you Slot 0 as only option.
I had this issue several times, Slot 0 in a 2801 is a special Slot with reduced capabilities.
See also here:
http://www.ciscotaccc.com/voice/showcase?case=K19287315
philippgrafl Thu, 07/16/2009 - 05:13
As this was the solution to your problem (moving the E1 to another slot than slot 0), i do not understand why my posting was rated with 1.
nwkotze@hotmail.com Mon, 07/13/2009 - 06:24
No Conference or transcoding Profiles configured this is a brand new config I strted. I eraced the old config.
I'm trying the Latest on the T train now...
nwkotze@hotmail.com Mon, 07/13/2009 - 07:19
Moved the PVDM to slot 1, did not work...
NAME: "PVDM 1", DESCR: "PVDMII DSP SIMM with four DSPs"
S2S-OVR-LAN-V-GW1(config-controller)#pri-group timeslots 1 - 31
nwkotze@hotmail.com Mon, 07/13/2009 - 09:58
S2S-OVR-LAN-V_STARTSTOP: Logging to host 10.0.10.128 port 514 started - CLI initiated
*Jul 13 16:10:28.031: %DSPRM-5-UPDOWN: DSP 8 in slot 0, changed state to up-GW1>
*Jul 13 16:10:29.575: %DSPRM-5-UPDOWN: DSP 7 in slot 0, changed state to up
*Jul 13 16:10:31.119: %DSPRM-5-UPDOWN: DSP 6 in slot 0, changed state to up
*Jul 13 16:10:32.663: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
S2S-OVR-LAN-V-GW1>
Correct Answer
pcameron Mon, 07/13/2009 - 14:43
nwkotze@hotmail.com Thu, 07/16/2009 - 00:46
Errors
1. Two or more items are incompatible. Selected or default-included item: [S280IPB-12415T] is incompatible with: [ PVDM2-64 ]. Please change one or more items.
To correct this error REPLACE the S280IPB-12415T from the following options
(2801 SOFTWARE:S280IPB:S280IPB-12415T)
S280AESK9-Advanced Enterprise Services
S280AISK9-Advanced IP Services
S280ES-Enterprise Services
S280ESK9-Enterprise Services w/Security
S280IPV-IP Voice
S280IPVK9-IP Voice w/Security
S280SPSK9-SP Services
OR
To correct this error REMOVE from the following options
PVDM2-64
64-Channel Packet Voice/Fax DSP Module
(2801 PVDM 0:PVDM2-64)
pcameron Thu, 07/16/2009 - 01:12
12.4.15T IP Base software is not "incompatible" with the PVDM2-64 DSP module. This code does not have any voice features, so the DSP and the voice cards won't be recognised and you will not be able to configure anything voice related.
Assuming you do have the correct version of code, does this have any relevance to moving the E1 card out of slot 0 into the recommended slot so PRI can be configured?
nwkotze@hotmail.com Thu, 07/16/2009 - 01:48
controller E1 0/3/0
controller E1 0/3/1
ip tcp synwait-time 10
S2S-OVR-LAN-V-GW1#config t
Enter configuration commands, one per line. End with CNTL/Z.
S2S-OVR-LAN-V-GW1(config)#controller E1 0/3/0
*Jul 16 10:04:26.515: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(1), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(2), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(3), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(4), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(5), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(6), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(7), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(8), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(9), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(10), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(11), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(12), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(13), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(14), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(15), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(17), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(18), changed state to up
*Jul 16 10:04:26.519: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(19), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(20), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(21), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(22), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(23), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(24), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(25), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(26), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(27), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(28), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(29), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(30), changed state to up
*Jul 16 10:04:26.523: %LINK-3-UPDOWN: Interface ISDN-VOICE 0/3/0:15(31), changed state to up
S2S-OVR-LAN-V-GW1(config-controller)#end
S2S-OVR-LAN-V-GW1#wr
Building configuration...
Compressed configuration from 4929 bytes to 2935 bytes
*Jul 16 10:04:46.975: %SYS-5-CONFIG_I: Configured from console by console[OK]
1 -rw- 33034640 Jul 16 2009 11:47:00 +01:00 c2801-ipvoice-mz.124-15.T9.bin
63877120 bytes total (30838784 bytes free)
S2S-OVR-LAN-V-GW1#
angel.gino Tue, 05/03/2011 - 06:37
I had the same problem. It moved vwic to slot 0 and it worked.
Thanks for the solution.
