Joe Clarke Mon, 07/13/2009 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is a known cosmetic bug. If there are no alerts, then you see Error instead of 0. The bug is CSCta34810, and a patch is available via the TAC.
yabilteryst Wed, 07/29/2009 - 04:50
Dear jclarke,
In bug toolkit and about this bug, there is no workaround. do you know an alternative way to solve?
Thanks.
Joe Clarke Wed, 07/29/2009 - 08:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can either generate some S0, S1, or S2 syslogs, or get the patch from the TAC. If your device supports EEM, you can easily generate an S1 syslog by configuring:
event manager applet sev1-syslog
event none
action 1.0 syslog priority alerts msg "Bogus Sev 1"
Then run:
Router#event manager run sev1-syslog
