How to play prompt that doesnt loaded by web in IVR?
Jul 13th, 2009
I have script that can record prompts to the directory c:\promptsscript A.
Then script B should replay recorded prompt
How should I make IVR to play recorded prompt from not default directory?
antonio.vazquez Mon, 07/13/2009 - 06:05
you can try to create a Document Var using the file path that you have created before and then play this Document.
I think that this solution is suitable for you.
Antonio
If you found this post helpful, please rate it.
