2960g connection issue
Jul 13th, 2009
I have a 2960 connected to a 3560 at 100/full. The port shows up w/ errors but I cannot ping the vlan on the 2960.
Auto mdix is on. Any thoughts?
sudip.acharya1 Mon, 07/13/2009 - 05:18
In addition, the 3560 port stat's showing a large amount of packets with errors. I already swapped out the cables but didnt help.
sudip.acharya1 Mon, 07/13/2009 - 12:10
When I set Speed and Duplex to auto, the port status is UP (connects at 100/half). Any other combo (100/auto or auto/Full, etc) results in the port to be down.
Here is the sho int:
FastEthernet0/18 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0014.1cd8.0394 (bia 0014.1cd8.0394)
Description: CLTSW102 MGMT Connection
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,reliability 255/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Half-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 04:13:13
Queueing strategy: fifo
Output queue: 0/40 (size/max)
11392 packets input, 837637 bytes, 0 no buffer
Received 10505 broadcasts (0 multicast)
0 watchdog, 9317 multicast, 0 pause input
1072 packets output, 117964 bytes, 0 underruns
0 output errors, 0 collisions, 7 interface resets
Sho int vlan:
cltsw01#sho int trunk
Port Mode Encapsulation Status Native vlan
Gi0/1 on 802.1q trunking 1
Gi0/2 on 802.1q trunking 1
Gi0/3 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/1 1-2,5,119
Gi0/2 1-2,5-6,119
Gi0/3 1-2,5
Port Vlans allowed and active in management domain
Gi0/1 1-2,5,119
Gi0/2 1-2,5-6,119
Gi0/3 1-2,5
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1 1-2,5,119
Gi0/2 1-2,5-6,119
Gi0/3 1-2,5
glen.grant Mon, 07/13/2009 - 13:35
The port will show down with anything other than auto for speed and duplex because you are using mdix which only works when the port is set as auto . If you want to hardcode the speeds and duplex then you will have to get a crossover cable to go to the other switch. If using mdix then set "both" ends as auto and it should negotiate ok .
sudip.acharya1 Mon, 07/13/2009 - 14:35
This has been resolved. We did not specify the encapsulation type.
Thanks everyone.
