ACE module redirect/rewrite issue
Jul 13th, 2009
I am having a redirect/rewrite problem with my ACE module. When the user types in https://citix.com and accepts the cert, I need the ace to add the following path to the url.../citrix/accessplatform/auth/login.aspx. That part works, but the page is returned as "http" and with the real server IP address in an unencrypted session versus https and the vip. I thought the action-list would fix this problem, but it had no effect. Any suggestions would be appreciated.
access-list IB extended permit ip any any
probe tcp connect
interval 5
faildetect 5
passdetect count 10
probe http web-connect
interval 5
passdetect count 6
request method get url /citrix/accessplatform/auth/login.aspx
expect status 200 302
connection term forced
parameter-map type http HTTP_Secure_Params
case-insensitive
persistence-rebalance
set header-maxparse-length 8192
action-list type modify http ACTION
ssl url rewrite location "172.16.252.50"
ssl url rewrite location "citrix"
rserver host citrix-01
ip address 172.16.252.10
inservice
rserver host citrix-02
ip address 172.16.252.11
inservice
rserver redirect citrix-redirect
webhost-redirection http://172.16.252.10/citrix/accessplatform/auth/login.aspx 301
inservice
rserver redirect citrix-redirect-02
webhost-redirection http://172.16.252.11/citrix/accessplatform/auth/login.aspx 301
inservice
ssl-proxy service SSL
key citrixkey
cert certnew.pem
serverfarm redirect Redirect-farm
inservice
inservice
serverfarm host citrix-farm
rserver citrix-01 81
inservice
rserver citrix-02 81
inservice
sticky http-cookie citrix.nnn citrix-sticky
timeout 720
replicate sticky
serverfarm Redirect-farm
class-map type http loadbalance match-any redirect
match http url citrix
class-map match-all HTTPS-VIP
match virtual-address 172.16.252.50 tcp eq https
policy-map type loadbalance first-match SLB
class class-default
sticky-serverfarm citrix-sticky
action ACTION
policy-map multi-match client-vip1
class HTTPS-VIP
loadbalance vip inservice
loadbalance policy SLB
loadbalance vip icmp-reply
appl-parameter http advanced-options HTTP_Secure_params
ssl-proxy server SSL
interface vlan 252
access-group input IB
service-policy input client-vip1
no shutdown
Martin Kyrc Tue, 07/14/2009 - 03:35
redirection is without http/https in the front. You can redirect only to another domain/path/.
You must correct define ssl rewrite condition. for example:
ssl url rewrite location DOMAIN-or-IP sslport 443 clearport 80
For you is DOAMIN-or-IP 172.16.252.10 and .11. Try it.
martin
mcroberts Tue, 07/14/2009 - 05:02
I added the "sslport 443 clearport 80" commands under the action-list and it seems that they are the default since they do not show up in the config.
Martin Kyrc Tue, 07/14/2009 - 05:05
right. sslport 443 and clearport 80 is default and it not shows in configuration. it works now (whit correct ip addresses) or not?
mcroberts Tue, 07/14/2009 - 05:24
I still have the same outcome. The user only sees "http" in the url versus the "https"
mcroberts Tue, 07/14/2009 - 05:25
mcroberts Tue, 07/14/2009 - 05:35
probe tcp connect
interval 5
faildetect 5
passdetect count 10
interval 5
passdetect count 6
case-insensitive
inservice
inservice
inservice
inservice
key citrixkey
cert certnew.pem
inservice
inservice
inservice
inservice
timeout 720
replicate sticky
class class-default
action ACTION
class HTTPS-VIP
interface vlan 252
no shutdown
Martin Kyrc Tue, 07/14/2009 - 05:46
this is correct??
inservice
inservice
it should be https instead http:
webhost-redirection httpS://172.16.252.10/citrix/accessplatform/auth/login.aspx 301
inservice
webhost-redirection httpS://172.16.252.11/citrix/accessplatform/auth/login.aspx 301
inservice
Martin Kyrc Tue, 07/14/2009 - 06:00
correct data flow for your configuration is:
1. client access https://172.16.252.50/
2. ACE send HTTP redirect (301) to client to http(s)://172.16.252.11/citrix/accessplatform/auth/login.aspx
3. browser receive this http redirect and tried get new url: http(s)://172.16.252.11/citrix/accessplatform/auth/login.aspx
^^ do you need this data flow?
mcroberts Tue, 07/14/2009 - 07:06
It does work when I go to that page with http only... the server is only listening on port 80.
Martin Kyrc Wed, 07/15/2009 - 00:12
:) ...here is a problem. ace send to client redirect to http and you need access from client to https (ssl terminated on ace? - if true, configuration is wrong, because as I wrote before your configuration has 3 steps - access to vip, redirect send to client, client access to new location).
It's clear?
mcroberts Wed, 07/15/2009 - 03:56
I am reworking the configuration later today and will post the new final. Thank you for the input.
