Problems with VPN ASA 5510
vidaluzarista
Hi All
I have a ASA 5510, I have configure 2 VPN, router 850-ASA is OK, but I can't establish the other VPN ASA-Astaro, the error is:
Jul 09 15:35:57 [IKEv1]: Group = 200.50.2.114, IP = 200.50.2.114, QM FSM error (P2 struct &0x3bcd8c0, mess id 0x4f4f1e75)!
Jul 09 15:35:57 [IKEv1]: Group = 200.50.2.114, IP = 200.50.2.114, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
Jul 09 15:35:57 [IKEv1]: Group = 200.50.2.114, IP = 200.50.2.114, Removing peer from correlator table failed, no match!
Jul 09 15:36:03 [IKEv1]: Group = 200.50.2.114, IP = 200.50.2.114, construct_ipsec_delete(): No SPI to identify Phase 2 SA!
Jul 09 15:36:03 [IKEv1]: Group = 200.50.2.114, IP = 200.50.2.114, Removing peer from correlator table failed, no match!
My configuration for VPN is:
ACL:
access-list Internet_cryptomap_40 extended permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list Internet_cryptomap_60 extended permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
VPN:
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association lifetime kilobytes 4608000
crypto map Internet_map 20 match address Internet_cryptomap_20_1
crypto map Internet_map 20 set peer 186.1.10.74
crypto map Internet_map 20 set transform-set ESP-3DES-MD5
crypto map Internet_map 20 set security-association lifetime seconds 86400
crypto map Internet_map 20 set security-association lifetime kilobytes 4608000
crypto map Internet_map 20 set nat-t-disable
crypto map Internet_map 40 match address Internet_cryptomap_40
crypto map Internet_map 40 set peer 165.98.233.180
crypto map Internet_map 40 set transform-set ESP-3DES-MD5
crypto map Internet_map 40 set security-association lifetime seconds 86400
crypto map Internet_map 40 set security-association lifetime kilobytes 4608000
crypto map Internet_map 60 match address Internet_cryptomap_60
crypto map Internet_map 60 set peer 200.50.2.114
crypto map Internet_map 60 set transform-set ESP-3DES-MD5
crypto map Internet_map 60 set security-association lifetime seconds 28800
crypto map Internet_map 60 set security-association lifetime kilobytes 4608000
crypto map Internet_map interface Internet
isakmp identity address
isakmp enable Internet
isakmp enable management
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption aes
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group DefaultRAGroup ipsec-attributes
isakmp keepalive threshold 10 retry 2
tunnel-group 186.1.10.74 type ipsec-l2l
tunnel-group 186.1.10.74 ipsec-attributes
pre-shared-key *
tunnel-group 165.98.233.180 type ipsec-l2l
tunnel-group 165.98.233.180 ipsec-attributes
pre-shared-key *
tunnel-group 200.50.2.114 type ipsec-l2l
tunnel-group 200.50.2.114 ipsec-attributes
pre-shared-key *
Thanks in Advanced
vmoopeung
Level 5
Level 5
This typically means one of a few things including, incorrect peer address configured in the L2L setup page, mis-matched local and remote newtork definitions, Agressive Mode vs. Main Mode misconfig, and IKE Proposal parameters not matching up on both ends.
