CE520G switch connected to UC520 reports undersized frames generated by UC520
Jul 13th, 2009
  • Bronze, 100 points or more
I'm sure that I must have a smartport or other setting incorrect, as I continue to get a notification in CCA from a CE520G switch that my UC520 is generating undersized frames.  The UC520 is connected on it's expansion port to the CE520G's Gi25 port.  As it stands right now, the UC520's expansion port has a "switch" smartport applied.  The CE520G's Gi25 port also has a "switch" smartport applied.  Does this need to be set with a "Router" profile?  From my memory, I tried that once and lost comm between the UC520 and the switch.  Thanks,
Seth
Marcos Hernandez Mon, 07/13/2009 - 07:36
  • Blue, 1500 points or more
Yes, the smartport role on the CE520 side needs to be set as "Router".
Marcos
sethschmautz Mon, 07/13/2009 - 07:38
Thanks for the quick reply, Marcos, I'll try it out tonight.
Seth
