call from PSTN keep ringing forever in my extension on the gateway 2811
Answered Question
Jul 13th, 2009
hi
i have a issue, when somebody make a call from pstn to my extension in the gateway, but i dont answer and the caller offhook the call, the ip phone keeps ringing forever....
the only way to stop ringing is disconnect the line from the fxo card.
this is the config on the gateway:
voice-port 0/3/0
supervisory disconnect dualtone mid-call
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
connection plar 1003
dial-peer voice 2 voip
destination-pattern 1003
session target ipv4:192.168.1.230
this is the debug vpm signal:
ROUTER2811#
*Jul 13 16:01:11.218: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0000]f
xols_onhook_ringing
*Jul 13 16:01:11.218: htsp_timer - 125 msec
*Jul 13 16:01:11.346: htsp_process_event: [0/3/0, FXOLS_WAIT_RING_MIN, E_HTSP_EV
ENT_TIMER]fxols_wait_ring_min_timer
*Jul 13 16:01:11.346: htsp_timer - 10000 msec
*Jul 13 16:01:11.694: htsp_process_event: [0/3/0, FXOLS_RINGING, E_DSP_SIG_0100]
*Jul 13 16:01:11.694: fxols_ringing_not
*Jul 13 16:01:11.694: htsp_timer_stop
*Jul 13 16:01:11.694: htsp_timer_stop3 htsp_setup_ind
*Jul 13 16:01:11.694: [0/3/0] get_local_station_id calling num= calling name= ca
lling time=07/13 16:01 orig called=
*Jul 13 16:01:11.698: htsp_process_event: [0/3/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_S
ETUP_ACK]
*Jul 13 16:01:11.698: fxols_wait_setup_ack:
*Jul 13 16:01:11.698: [0/3/0] set signal state = 0xC timestamp = 0fxols_check_au
to_call
*Jul 13 16:01:11.702: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_HTSP_PROCE
EDING]fxols_offhook_proc
*Jul 13 16:01:11.702: htsp_timer - 120000 msechtsp_alert_notify
*Jul 13 16:01:11.766: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_HTSP_ALERT
]fxols_offhook_alerthtsp_call_service_msghtsp_call_service_msg not EFXS (2)
ROUTER2811#
to stop the call ringing forever, is disconeccting the line fom the fxo, this is the same debug when i diconnect the line:
ROUTER2811#
*Jul 13 16:01:19.878: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_DSP_SIG_11
00]fxols_offhook_disc
*Jul 13 16:01:19.878: htsp_timer2 - 350 msec
*Jul 13 16:01:20.230: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_HTSP_EVENT
_TIMER2]fxols_disc_confirm
*Jul 13 16:01:20.230: htsp_timer_stop
*Jul 13 16:01:20.230: htsp_timer_stop2
*Jul 13 16:01:20.230: htsp_timer_stop3
*Jul 13 16:01:20.234: htsp_process_event: [0/3/0, FXOLS_PROCEEDING, E_HTSP_RELEA
SE_REQ]fxols_offhook_release
*Jul 13 16:01:20.234: htsp_timer_stop
*Jul 13 16:01:20.234: htsp_timer_stop2
*Jul 13 16:01:20.234: htsp_timer_stop3
*Jul 13 16:01:20.234: [0/3/0] set signal state = 0x4 timestamp = 0
*Jul 13 16:01:20.234: htsp_timer - 2000 msec
*Jul 13 16:01:22.234: htsp_process_event: [0/3/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_
TIMER]fxols_guard_out_timeout
*Jul 13 16:01:22.234: htsp_process_event: [0/3/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
ROUTER2811#
Correct Answer by Adrian Saavedra about 8 years 1 week ago
There are some posts in Netpro about this type of problems.
Also read about this:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Regards.
Overall Rating: 5 (1 ratings)
lwai Wed, 07/15/2009 - 00:56
Under the voice port, you should define the cptone.
Michael.
