WVC200 Camera wont work with FireFox v3.5
Jul 13th, 2009
WVC200 camera with Firmware 1.2.1
on manually assigned address on Linksys Router WRT350N firmware v1.04.4 at
Vista HM Premium SP2
Works fine on IE8
But not at all on Firefox 3.5
Any ideas?
Steven DiStefano Mon, 07/13/2009 - 08:03
What wont work?
The Setting of Motion Detection Windows?
Yes, this is a known limit (ActiveX needed).
Also that WVC200 model is an OLD camera & is currently not supported on the SWVMS16 Monitoring client just to point that out for you.
Steve D
SE Sales Channel
terryhitt Mon, 07/13/2009 - 08:24
Steve, Thanks for your response
ActiveX issue?
Am I missing an add-in for firefox?
The WVC200 web browser works fine in IE8 but not in Firefox 3.5
Steven DiStefano Mon, 07/13/2009 - 08:32
Oh OK.  Well, you will stumble into the 'motion detection window set up" requiring IE, but you are saying you cannot launch the browser at the camera GUI at all?
That is not normal and I have not heard of this and have that camera and use FF for years on it.  You dont have a proxy or anything like that set on FF do you?
Can you get the the router typing the full path:  http://192.168.x.1
Are you on the LAN and typing the IP address of the Camera and you ahvent set an alternate HTTP port or enabled HTTPS or anything did you?  Althought that would also fail for IE maybe unless different SSL if using HTTPS?
terryhitt Tue, 07/21/2009 - 05:29
per another user, i changed the settings (Setup / Image / Image Type) to mjpeg and all works fine now in FireFox 3.5.1
Thanks all!
