NTP server.
Jul 13th, 2009
hi.
i want to create NTP server on ASA 5540 firewall, its work to synchronize to all my devise in network.
and if yes then tell me how i installed it on my asa.
srue Mon, 07/13/2009 - 09:25
ASA's cannot be NTP servers, only NTP clients.
mitang.prajapati Mon, 07/13/2009 - 10:27
ok then tell me what command i give to configure my ntp client i have windows ntp server.
srue Mon, 07/13/2009 - 10:34
on the asa:
asa(config)# ntp server x.x.x.x
srue Mon, 07/13/2009 - 10:45
use the "clock timezone" command to set the timezone. use "clock summertime" if you use daylight savings.
mitang.prajapati Mon, 07/13/2009 - 10:55
i had give this command
ntp server x.x.x.x
but after this its not synchronize with time.
now what i do ?
mitang.prajapati Mon, 07/13/2009 - 11:09
its shown me wrong time so what i do ?
and how i check that time is properly synchronize?
srue Mon, 07/13/2009 - 11:33
show ntp status
show clock
if it's not working, debug ntp.
can you ping the ntp server from the asa?
mitang.prajapati Mon, 07/13/2009 - 11:54
yes
i ping that server.but i got time differnce between server and asa. its around 5min.
robertson.michael Tue, 07/14/2009 - 06:23
Hi Mitang,
I had a similar issue at one point in the past--the ASA was not syncing properly with a Windows 2003 NTP server. I believe the ASA was reporting the NTP server as having a status of "insane".
I am not 100% positive, but I believe these are the instructions I followed to resolve this issue. Take a look at the section called "Configuring the Windows Time service to use an internal hardware clock":
http://support.microsoft.com/kb/816042/
Hope that helps.
-Mike
