Need help with remote access vpn
Jul 13th, 2009
I have a PIX 501 with an active L2L tunnel on it. I have also just added a remote access vpn, in which I'll be connecting to the inside network with the Cisco vpn client using local authentication. I've got it setup so I can authenticate and get an assigned ip address, but I cannot ping across to the inside network anywhere. I have sysopt enabled so that is not the issue. I'm not sure if something is conflicting with the L2L tunnel or not. I've attached the config and broken it up to best describe what its doing. Can someone please advise on to what the issue could be?
acomiskey Mon, 07/13/2009 - 10:15
  • Green, 3000 points or more
Add...
isakmp nat-traversal
mjsully Mon, 07/13/2009 - 10:25
That did it!!
Can you explain why that is needed? Appreciate the fix!
mjsully Mon, 07/13/2009 - 15:29
That's where I'm confused. I'm not NATn'g anything.
