Q931 errors with Cisco IAD ISDN PRI To 3COM NBX3000
vgioia5090
CAN ANYONE TELL ME WHAT THES DEBUG ERROR MESSAGES MEAN. ALSO HERE IS MY IAD CONFIG AS WELL. NEED HELP PLEASE!
Jul 13 15:55:51.848: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:55:51.848: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:55:52.844: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:55:52.844: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:55:53.844: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:55:53.844: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:55:54.844: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:55:54.844: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:55:59.844: ISDN Se0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0021
Cause i = 0x809F - Normal, unspecified
Jul 13 15:55:59.848: ISDN Se0/0:23 SERROR: L3_GetUser_NLCB: EVENT 0X5A No NLCB 2
Jul 13 15:55:59.848: ISDN Se0/0:23 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x8021 callid 0x0
Jul 13 15:56:04.348: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:56:04.348: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:56:05.344: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:56:05.344: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:56:06.344: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:56:06.344: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:56:07.344: ISDN Se0/0:23 Q931: RX <- BAD PACKET()
Jul 13 15:56:07.344: ISDN Se0/0:23 Q931: do_statistics: protocol 0x80 protocol not supported.
Jul 13 15:56:12.344: ISDN Se0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0022
Jul 13 15:56:12.348: ISDN Se0/0:23 SERROR: L3_GetUser_NLCB: EVENT 0X5A No NLCB 2
Jul 13 15:56:12.348: ISDN Se0/0:23 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x8022 callid 0x0
PRE-PRI Config
service password-encryption
hostname MILL
boot-start-marker
boot-end-marker
card type t1 1
logging buffered 2000000 debugging
no aaa new-model
clock timezone est -5
clock summer-time edt recurring
network-clock-participate wic 0
network-clock-participate T1 1/0
network-clock-participate T1 1/1
network-clock-select 1 T1 1/1
ip cef
ip name-server 66.119.112.2
ip name-server 4.2.2.2
isdn switch-type primary-ni
trunk group MCC
voice-card 0
voice call send-alert
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 1 hs-redundancy 0 fallback pass-through g711ulaw
sip
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g729r8
controller T1 0/0
framing esf
fdl both
clock source internal
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
controller T1 0/1
framing esf
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 1/0
framing esf
linecode b8zs
controller T1 1/1
framing esf
linecode b8zs
class-map match-all voip
match access-group 101
match ip precedence 5
policy-map voice-policy
class voip
priority percent 25 512000
vgioia5090
translation-rule 40
Rule 1 null null
interface Multilink200
ip address 209.150.X.X 255.255.255.X
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 200
service-policy output voice-policy
interface FastEthernet0/0
description WAN
ip accounting output-packets
ip route-cache flow
duplex full
speed 100
no cdp enable
interface Serial0/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice modem
isdn supp-service name calling
isdn send-alerting
isdn negotiate-bchan resend-setup
isdn outgoing-voice info-transfer-capability 3.1kHz-audio
isdn outgoing ie facility
isdn outgoing ie called-number
no cdp enable
interface FastEthernet0/1
description LAN
ip route-cache flow
duplex auto
speed auto
no cdp enable
interface Serial0/1:1
no ip address
encapsulation ppp
ppp multilink
interface Serial1/0:1
no ip address
encapsulation ppp
ppp multilink
interface Serial1/1:1
no ip address
encapsulation ppp
ppp multilink
no ip http server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 209.150.X.X
access-list 101 permit ip any any dscp ef
dialer-list 1 protocol ip permit
no cdp run
control-plane
voice-port 0/0:23
translate calling 40
voice-port 2/0
ren 5
disconnect-ack
loss-plan plan4
input gain 2
output attenuation 9
echo-cancel coverage 24
no vad
no comfort-noise
timeouts interdigit 3
timing hookflash-in 400 150
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
dial-peer voice 2 voip
tone ringback alert-no-PI
huntstop
preference 2
destination-pattern T
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session protocol sipv2
session target sip-server
session transport udp
codec g711ulaw
fax-relay ecm disable
fax rate 9600
clid strip pi-restrict
clid strip name
no vad
dial-peer voice 100 pots
destination-pattern 77256290XX
direct-inward-dial
forward-digits 7
dial-peer voice 300 voip
destination-pattern .T
codec g711ulaw
dial-peer voice 501 voip
incoming called-number 77256290XX
codec g711ulaw
dial-peer voice 406 pots
port 2/0
authentication username 77256290XX password
gateway
timer receive-rtcp 120
timer receive-rtp 1200
sip-ua
no remote-party-id
retry invite 4
retry bye 2
retry cancel 2
registrar dns:mars.pbx-change.com expires 3600
sip-server dns:mars.pbx-change.com
line con 0
password 7
line aux 0
transport preferred none
transport output none
line vty 0 4
password
login
ntp clock-period 17180084
ntp server 198.31.248.6 prefer
end
ALSO THIS ONY SEEMS TO HAPPEN ON OUTGOING ONLY. WE CAN RECEIVE INCOMING CALLS
